How to Clear Alarms in WAAS
As per below logs it's showing some critical & major alarms but it was happend on JUlLY 10th and SEPT 11th  but still showing same alarms.
Please help me clear those alarms.
I want to know how to clear Alarms in this WAAS.
Logs:
From WAAS002:
-WAAS002#sh alarms detail
Critical Alarms:
        Alarm ID                 Module/Submodule               Instance
   1 mstore_key_retrieval      cms                          ssl_mstore_key
     Sep 11 21:23:37.080 SGT, Processing Error Alarm, #000004, 3000:700008
     Unable to generate and/or retrieve SSL managed store encryption key from the Key Manager
   2 mstore_key_failure        sslao                        mstore_key_failure
     Sep 11 21:22:48.193 SGT, Processing Error Alarm, #000003, 26000:26002
     Failed to open SSL store due to failure in getting key from Central Manager.
Major Alarms:
   1 rtr_unreachable           WCCP/svc061/rtr10.154.13.126
     Sep 11 21:20:53.153 SGT, Communication Alarm, #000001, 17000:17002
     WCCP router 10.154.13.126 unreachable for service id: 61.
   2 rtr_unreachable           WCCP/svc062/rtr10.154.13.126
     Sep 11 21:20:53.153 SGT, Communication Alarm, #000002, 17000:17002
     WCCP router 10.154.13.126 unreachable for service id: 62.
Minor Alarms:
None
-WAAS002#
From WAAS003:
-WAAS03#sh alarms detail
Critical Alarms:
     Jul 10 16:37:55.606 SGT, Processing Error Alarm, #000001, 3000:700008
     Jul 10 16:49:19.395 SGT, Processing Error Alarm, #000013, 26000:26002
Major Alarms:
   1 psu_ac_status             sysmon/psu1_vinok            no power
     Jul 10 16:39:15.185 SGT, Equipment Alarm, #000003, 1000:445040
     Power Supply Unit (PSU1) reports AC lost
Minor Alarms:
None
-WAAS03#
From WAAS004:
-WAAS004#show ala detail
Critical Alarms:
     Jul 10 16:06:19.143 SGT, Processing Error Alarm, #000003, 3000:700008
e Key Manager
     Jul 11 02:37:57.725 SGT, Processing Error Alarm, #000454, 26000:26002
Major Alarms:
     Jul 10 16:07:28.731 SGT, Equipment Alarm, #000004, 1000:445040
Minor Alarms:
None
-WAAS004#
-WAAS004#
Srin_G
Level 3
Level 3
If it still shows it means the alarms are still there. You need to fix it not clear them.
The keystore alarm is due to ssl certificates it might be expired. I had that one too simply generate another certificate in the waas it will fix it.
rtr unreachable is because the waas cant see the router you specified. Go the wccp settings of the waas and see whether you have the router list rightly configured and have the same secret in the waas and router.
Srini
Srin_G
Level 3
Level 3
Srini
Great, Thanks srini........
I will check and update you if anything............
Senthil
