Upgrade performace ACE20 module
Alejandro Brown
I have a ACE20 module with a performance of 4 Gbps.
I want to upgrade the performace from 4 Gbps to 8 Gbps.
Is correct the following SKU for the upgrade?
ACE30-UPG-08-K9=ACE10 or ACE20 to ACE30 Upgrade for 8 Gbps   Throughput
And if i want to upgrade the performace to 16Gbps is correct the sku?
ACE30-UPG-16-K9=ACE10 or ACE20 to ACE30 Upgrade for 16 Gbps   Throughput
I noticed that the price list of both codes is the same....
Is it right for the SKUs listed I get the new module with the performance ACE30 requested?
Alejandro
Daniel Arrondo Ostiz
Hi Alejandro,
The first thing I want you to be aware is that the throughput increase is just done by adding a new license. You will not get a ACE30 module
With that said, if you are currently using an ACE20 module, the correct licenses to order would be:
ACE-UPG1-LIC=
Upgrade License from 4 Gbps to 8 Gbps for Cisco ACE10 and Cisco ACE20
ACE-UPG2-LIC=
Upgrade License from 8 Gbps to 16 Gbps for Cisco ACE20
For all the available options, please, refer to the ACE data sheet:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/prod_bulletin0900aecd8045859e.html
Daniel
Hi Alejandro,
ACE-UPG1-LIC=
ACE-UPG2-LIC=
Daniel
Daniel,
thanks for the answer.
Alejandro
