Upgrading Procedure for SSL Module (WS-SVC-SSL-1)
tojackson
Trying to upgrade image on SSL module, but there is not enough space on flash. How do you delete old image on SSL module to create more space for new image?
Kanwaljeet Singh
Cannot find anything related to this. SSL-M has no BU support and if your code is stable then i would suggest staying on it. You can open a TAC case for further assistance.
Kanwal
Note: Please mark answers if they are helpful.
Is it possible to delete the old image from flash via the maintenance partition? The version of code needed to support additional SHA-1 and SHA-2 certificates I believe... not 100% sure though.
Which version are you upgrading to? I can check regarding the support of additional ciphers. I don't think SHA-2 would be there since the support for SHA-2 came in ACE in A4 train only. But i can check the details.
Regarding deletion of old image, i did extensive search but couldn't find anything around it.
Kanwal
