using the same class-map for different VIPs
axfalk
Level 7
Level 7
We're running ACE SM 5.3(1) and I was wondering if the ACE would allow associating multiple VIPs with the same class-map?
Thanks.
_ Greg
thiland
Level 8
Level 8
That is possible, assuming you're talking about something like this:
class-map match-any CLASS-VIP-APPLICATION1
  2 match virtual-address 10.10.10.10 tcp eq 80
  3 match virtual-address 10.10.10.10 tcp eq 8080
Thanks for your response. What I had in mind is more like this:
  2 match virtual-address 10.10.10.20 tcp eq 80
Thanks again.
Hi Greg,
Yes you can. You can also define a range:
switch/Admin(config-cmap)# 2 match virtual-address 10.1.1.1 ?
  <1-255>    Ip protocol number
  <A.B.C.D>  Specify virtual ip-address mask to use for a range of VIPs
Kanwal
Note: Please mark answers if they are helpful.
thanks much.
