vCUBE and AWS
Joshua-Thomas
Hello All,
I am working to stand up a vCUBE AMI(Version 17.06.01a) on AWS. I connect to the instance using the "ec2-user" and a generated certificate as stated in the marketplace overview. However, when I log into the terminal to start configuration, the vCUBE asks for a password. Is this default password documented anywhere? Are there any gotchas that I should be aware of?
I've also tried logging in by using an EC2 Serial Session but I am asked for a Username/Password combination of which I am not sure. If anyone has any experience with getting the initial configuration on a vCUBE done, I would appreciate the help.
0 Replies 0
