VIP and servers on same IP space
dafault
I have 2 web servers, 172.16.10.80 & .81, and a CSS11154 connected to a Cat2950. The CSS's VIP address for the web servers is 172.16.10.95. My problem is no device within or outside this segment can access the web servers utilizing the VIP address. Originally, I had the servers directly connected to the CSS and the VIP worked but when I needed to transfer large quantities of data directly to the servers the throughtput was extremely bad so I moved the servers to the Cat2950.
jfoerster
Level 4
Level 4
HI,
sounds as if the return flow is directed to the server and not to the CSS. This breaks the flow. Please verify this with a sniffer. If this is the case you have to do client NAT (i.e use the VIP as source address). An example can be found in the following link http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_example09186a00802206a3.shtml.
Joerg
