vip not responding to client requests on ACE
12pratham
client is unable to establish a connection to the backend servers via the vip on port 389 ,636 configured that servers are listening on these ports .
even the probe is successful on port 389
but not getting any response back from the servers
below is the config and output of service-policy
probe scripted PROBE_LDAP_389
  description This is a scripted Probe for LDAP
  interval 60
  passdetect interval 60
  receive 20
  script LDAP_PROBE
serverfarm host S1
  probe PROBE_LDAP_389
  rserver s01
    inservice
  rserver s02
    inservice
sticky ip-netmask 255.255.255.255 address source S1_STICKY
  replicate sticky
  serverfarm S1
class-map match-all S1_CLASS
  2 match virtual-address 10.12.44.27 tcp any
policy-map type loadbalance first-match S1_POLICY
  class class-default
    sticky-serverfarm S1_STICKY
policy-map multi-match POLICY
class S1_CLASS
loadbalance vip inservice
loadbalance policy S1_POLICY
loadbalance vip icmp-reply active
production# sh service-policy POLICY class-map S1_CLASS detail
service-policy: POLICY
    class: S1_CLASS
     VIP Address:                              Protocol:  Port:
     10.12.44.27                              tcp    any
      loadbalance:
        L7 loadbalance policy: S1_POLICY
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        VIP DWS state: DWS_DISABLED
        Persistence Rebalance: DISABLED
        curr conns       : 1         , hit count        : 12
        dropped conns    : 0
        client pkt count : 33        , client byte count: 1728
        server pkt count : 0         , server byte count: 0
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
        L7 Loadbalance policy : S1_POLICY
          class/match : class-default
            LB action: :
               sticky group: S1_STICKY
                  primary serverfarm: S1
                    state:UP
                  backup serverfarm : -
            hit count        : 12
            dropped conns    : 0
            compression      : off
      compression:
        bytes_in  : 0                          bytes_out : 0
        Compression ratio : 0.00%
                Gzip: 0               Deflate: 0
      compression errors:
        User-Agent  : 0               Accept-Encoding    : 0
        Content size: 0               Content type       : 0
        Not HTTP 1.1: 0               HTTP response error: 0
        Others      : 0
Jorge Bejarano
Level 4
Level 4
Based on the output, it seems the traffic is reaching the ACE but the communications between the servers and the ACE is not properly done. Then we should make sure about some details here:
Do you have any device in between of the ace and servers?
What type of design do you have?(bridge mode, routed mode, one arm mode)
what is the default gateway of the servers?
Could you show us the configuration of the interface where you have configured service-policy input POLICY?
Could you show #show probe PROBE_LDAP_389 detail?
Jorge
