Vip Redundancy on CSS --- problems
glenngriffin
Community Member
Hi All~
I tried VIP reduandancy using a CSS pair and it didnt work.
Currently we have a flat network in our staging environment.Only one VLAN 100 is serving all machines.I was asked to introduce a CSS pair for some application testing.I introduced another VLAN 200 into the switch and attached servers and CSS's Server Vlan to it. See diagram at
http://download.fortifire.com/diagram.jpg
(Every server has two NICs only one active--solid green)
Every thing worked as long as I didnt shut down the primary CSS. As soon the primary CSS was down, I couldnt reach my servers.
I flushed the arp tables on both devices but I found that CAt6k was learning the MAC of Servers on wrong port-(port connected to the primary css which was down).Is this some kind of spanning tree problem?
I switched back to single vlan model and am now using CSS in Host-to-Host redundancy and every thing is running fine.
In a redundandt Layer 2 environment, is VIP based redundant CSS is not possible?
or I am making a silly mistake?
Glenn
Gilles Dufour
what was the servers default gateway ip address ?
Was it the redundant-interface ?
Could you ping from server to gateway after failover ?
Are you using dual nic on the servers ?
Could you give us the CSS config.
Gilles.
