vlan based default gateway
barzus
Community Member
Alteon Web OS allows you to assign different default gateways for each VLAN. You can effectively map multiple customers to specific gateways on a single switch.
do cisco load balancers support different default gateway for each vlan?
5 Replies 5
cody.rowland
Level 2
Level 2
Unfortunately, no. At least not as far as I can tell. I've desperately been trying to find a way to do this and I'm having no luck at all.
scottmac
Level 11
Level 11
I'm not familiar with the specific product, but wouldn't you be able to define the specific gateway based on the DHCP scope?
Even if you don't really want to use DHCP (low count of static addresses), you COULD still use DHCP, assign "permanant" IPs based on the port MAC address, and for each subnet's scope, define the default gateway for that scope in the properties.
....or am I missing something?
FWIW
Scott
In this case, DHCP doesn't apply because we're talking about load balancing servers using a CSS. All IP addresses need to be statically assigned.
Cisco put me on the list too, this is a feature the CSS's really need!!
Gilles Dufour
one way of doing it today would be to define a serverfarm for each gateway, and have a vserver match_all for every vlan.
For example,
serverfarm gateway_1
no nat client
no nat server
real
x.x.x.x
serverfarm gateway_2
vserver gateway_vlan1
virtual 0.0.0.0 /0 any
vlan
vserver gateway_vlan2
vlan
