VRRP fail over and load balancing CSS11501
t.doherty
I have 2 CSS11501s that I want to load balance 2 web servers with. If I run VRRP on the VLAN interfaces of the CSSs so only one responds can I still connect each web server to a separate CSS and still do load balancing between the web servers?
I know it can be done with the web servers on a switch but I don't have the switch port capacity so I would like to plug the web servers directly in to the CSSs.
-CSS1----Web1
R---S
-CSS2----Web2
Gilles Dufour
yes you can.
You need a trunk between the CSS however and the command 'ip uncond-bridging' on both CSS to allow briding between the 2.
Gilles.
