WAAS and Etherchannel
wrobbin
So i setup an etherchannel with my WAAS and while im not
experiencing any issues...im seeing something a little odd
WAE
primary-interface PortChannel 1
ip address x.x.x.x x.x.x.x
exit
interface GigabitEthernet 1/0
channel-group 1
exit
interface GigabitEthernet 2/0
channel-group 1
exit
Switch
interface Port-channel5
description WAAS Port-Channel
switchport access vlan 5
load-interval 30
end
interface GigabitEthernet1/0/18
description WAE-0423-574
channel-group 5 mode on
spanning-tree portfast
end
interface GigabitEthernet2/0/12
end
but when i do a show po5 this is what i get
sh int po5
Port-channel5 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0022.bd3f.1d12 (bia 0022.bd3f.1d12)
  Description: WAAS Port-Channel
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 0/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi1/0/18 Gi2/0/12
  Last input never, output 00:00:00, output hang never
  Last clearing of "show interface" counters 23:03:19
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     14696018 packets input, 9052608888 bytes, 0 no buffer
     Received 6310 broadcasts (2766 multicasts)
     0 watchdog, 2766 multicast, 0 pause input
     12948000 packets output, 5120404982 bytes, 0 underruns
0 Replies 0
