CSS and Exchange Mobile ActiveSync not working
tholmes
I have a question relating to a CSS and Exchange Mobile devices The customer has 2 Exchange Client Access Servers CAS1 and CAS2 and has problems with ActiveSync on mobile devices. (OWA is working fine) I am trying to test Exchange ActiveSync (using the Microsoft test site https://www.testexchangeconnectivity.com) When I perform an ‘Exchange ActiveSync Autodiscover’ it works fine, but when I use the test ‘Exchange ActiveSync’, it fails Has anyone had this problem before or can suggest a fix please http://mobile.thamesriver.co.uk The config is underneath Any help would be appreciated Kind Regards Tony !*********************** SSL PROXY LIST *********************** ssl-proxy-list TRC_List   ssl-server 10   ssl-server 10 vip address x.x.x.x   ssl-server 10 cipher rsa-with-rc4-128-md5 x.x.x.x 80   ssl-server 10 rsakey myrsakey   ssl-server 10 rsacert myrsacert   active !************************** SERVICE ************************** service mobile1   ip address 10.1.230.200   keepalive type tcp   protocol tcp   port 80   active service mobile2   ip address 10.1.230.201   keepalive type tcp   protocol tcp   port 80   active service CASservice1_HTTP   protocol tcp   port 80   keepalive type tcp   ip address 10.1.230.200   string cashttp1   active   service CASservice2_HTTP   protocol tcp   port 80   keepalive type tcp   ip address 10.1.230.201   string cashttp2   active   service CASservice1_EPM   protocol tcp   port 135   keepalive type tcp   ip address 10.1.230.200   string EPM1   active service RPC_Address1   port 59533   keepalive type tcp   ip address 10.1.230.200   protocol tcp   active service RPC_Address2   port 59533   keepalive type tcp   ip address 10.1.230.201   protocol tcp   active service RPC_Mailbox1   protocol tcp   keepalive type tcp   ip address 10.1.230.200   port 59532   active service RPC_Mailbox2   protocol tcp   keepalive type tcp   ip address 10.1.230.201   port 59532   active service ssl_module1   keepalive type none   add ssl-proxy-list TRC_List   type ssl-accel   slot 3   active !*************************** OWNER *************************** owner TRC   content AuthHead     add service mobile1     add service mobile2     vip address x.x.x.x     protocol tcp     port 80     url "//mobile.thamesriver.co.uk/Microsoft-Server-ActiveSync"     active   content EPM     balance aca     add service CASservice1_EPM     add service CASservice2_EPM     protocol tcp     port 135     url "/*"     vip address x.x.x.x     advanced-balance sticky-srcip     sticky-inact-timeout 1     active   content OWA     balance aca     add service CASservice1_HTTP     add service CASservice2_HTTP     protocol tcp     port 80     url "/*"     vip address x.x.x.x     advanced-balance sticky-srcip-dstport     active   content RPC-Address     balance aca     add service RPC_Address1     add service RPC_Address2     port 59533     protocol tcp     advanced-balance sticky-srcip     vip address x.x.x.x     active   content RPC-Mailbox     balance aca     add service RPC_Mailbox1     add service RPC_Mailbox2     advanced-balance sticky-srcip     vip address x.x.x.x     port 59532     protocol tcp     active     content ssl-rule     vip address x.x.x.x     protocol tcp     port 443     add service ssl_module1     active !*************************** GROUP *************************** group RDP   add service TSservice1   add service TSservice2   add service TSservice3   add service TSservice4   add service TSservice5   add service TSservice6   add service TSservice7   vip address 172.26.100.190   active group WWW   add service CASservice1_HTTP   add service CASservice2_HTTP   vip address x.x.x.x   active TRC_CSS#
tholmes
duh!
I'll try that again....
OWA is working fine
I am trying to test Exchange ActiveSync (using the Microsoft test site https://www.testexchangeconnectivity.com) I perform an ‘Exchange ActiveSync Autodiscover’ it works fine, but when I use the test ‘Exchange ActiveSync’, it fails
When
http://mobile.thamesriver.co.uk config is underneath
The
Kind Regards Tony
  ssl-server 10
  active
service mobile1
  keepalive type tcp
  protocol tcp
  port 80
  active
service mobile2
  keepalive type tcp
  protocol tcp
  port 80
  active
  protocol tcp
  port 80
  keepalive type tcp
  string cashttp1
  active
  protocol tcp
  port 80
  keepalive type tcp
  string cashttp2
  active
  protocol tcp
  port 135
  keepalive type tcp
  string EPM1
  active
  port 59533
  keepalive type tcp
  protocol tcp
  active
  port 59533
  keepalive type tcp
  protocol tcp
  active
  protocol tcp
  keepalive type tcp
  port 59532
  active
  protocol tcp
  keepalive type tcp
  port 59532
  active
service ssl_module1
  keepalive type none
  type ssl-accel
  slot 3
  active
owner TRC
  content AuthHead
    add service AuthHead1
    add service AuthHead2
    vip address x.x.x.x
    protocol tcp
    port 80
    active
  content EPM
    balance aca
    protocol tcp
    port 135
    url "/*"
    vip address x.x.x.x
    active
  content OWA
    balance aca
    protocol tcp
    port 80
    url "/*"
    vip address x.x.x.x
    active
  content RPC-Address
    balance aca
    port 59533
    protocol tcp
    vip address x.x.x.x
    active
  content RPC-Mailbox
    balance aca
    vip address x.x.x.x
    port 59532
    protocol tcp
    active
  content ssl-rule
    vip address x.x.x.x
    protocol tcp
    port 443
    active
group RDP
  active
group WWW
  vip address x.x.x.x
  active
TRC_CSS#
