WAAS Configuration for 3750 Switch
james.robinson
I am configuring a 3750 switch with 12.2(52)SE according to:
(from https://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/3750_scg.pdf )
This example shows how to configure SVIs and how to enable the web cache service with a multicast group list. VLAN 299 is created and configured with an IP address of 175.20.20.10. Gigabit Ethernet port 1 is connected through the Internet to the web server and is configured as an access port in VLAN 299. VLAN 300 is created and configured with an IP address of 172.20.10.30. Gigabit Ethernet port 2 is connected to the application engine and is configured as an access port in VLAN 300. VLAN 301 is created and configured with an IP address of 175.20.30.50. Fast Ethernet ports 3 to 6, which are connected to the clients, are configured as access ports in VLAN 301. The switch redirects packets received from the client interfaces to the application engine.
Note Only permit ACL entries are being used in the redirect-list; deny entries are unsupported.
Switch# configure terminal
Switch(config)# ip wccp web-cache 80 group-list 15
Switch(config)# access-list 15 permit host 171.69.198.102
Switch(config)# access-list 15 permit host 171.69.198.104
Switch(config)# access-list 15 permit host 171.69.198.106
Switch(config)# vlan 299      WEB  SERVER
Switch(config-vlan)# exit
Switch(config)# interface vlan 299
Switch(config-if)# ip address 175.20.20.10 255.255.255.0
Switch(config-if)# exit
Switch(config)# interface gigabitethernet1/0/1
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 299
Switch(config)# vlan 300 WAE
Switch(config)# interface vlan 300
Switch(config-if)# ip address 171.69.198.100 255.255.255.0
Switch(config)# interface gigabitethernet1/0/2
Switch(config-if)# switchport access vlan 300
Switch(config)# vlan 301 CLIENTS
Switch(config)# interface vlan 301
Switch(config-if)# ip address 175.20.30.20 255.255.255.0
Switch(config-if)# ip wccp web-cache redirect in
Switch(config)# interface gigabitethernet1/0/3 - 6
Switch(config-if-range)# switchport mode access
Switch(config-if-range)# switchport access vlan 301
Switch(config-if-range)# exit
Question:  How do I configure my WAE to play nicely with this switch?
Bhavin Yadav
Hi James,
Here is the link to WCCP config part on WAE:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v441/configuration/guide/traffic.html#wp1041742
In your case, if my understanding is right, VLAN300 is where you want to connect WAE and WAE is also L2 adjacent. if that is true, here is the config you need on WAE:
wccp router-list 1 171.69.198.100
wccp tcp-promiscuous router-list-num 1 l2-redirect mask-assign l2-return
wccp version 2
Please note that 3750 supports L2 redirection only with redirect IN statements on 3750 interfaces connected to servers and clients.
Hope this helps.
Regards.
