WAAS Connection Limit
mike-greene
Level 4
Level 4
Will the WAE or CM show an error message if the connection limit is reached on a WAE?
Mike
5 Replies 5
Zach Seils
Level 7
Level 7
Mike,
A connection overload alarm will be raised on the CM when a WAE exceeds its maximum connection threshold.
Zach
Thanks Zach.
Hi all,
If the device reach to the maximum connection limit. What will device do? Actually i want to ask, "All current connection will be drop or not? or not compression?"
Best Regards.
When the WAE/WAVE device reached max connection limit - any new connections will go into pass through due to overload
Existing connections will be still be optimized.
Eric
If this answers your questions please mark as answered with a 5.
Thanx Eric,
