WAAS - Connection Type
asfar.zaidi
Level 3
Level 3
Hi All
I have 2 sites connected through WAAS (In line deployment) , when I am issuing command
show statistics connection all
192.168.27.185:445 192.168.64.25:3070 N/A PT Rjct Resources
192.168.201.141:445 192.168.64.31:2020 N/A PT Rjct Resources
192.168.64.25:3112 192.168.150.3:445 N/A PT Rjct Resources
192.168.64.25:3098 192.168.151.40:445 N/A PT Rjct Resources
192.168.64.25:3130 192.168.102.0:445 N/A PT Rjct Resources
192.168.16.101:445 192.168.55.148:1746 N/A PT Rjct Resources
192.168.111.12:445 192.168.64.31:1948 N/A PT Rjct Resources
192.168.64.31:1960 192.168.196.151:445 N/A PT Rjct Resources
192.168.64.25:3042 192.168.191.118:445 N/A PT Rjct Resources
192.168.6.214:445 192.168.64.25:3102 N/A PT Rjct Resources
192.168.74.175:445 192.168.64.31:1944 N/A PT Rjct Resources
192.168.55.14:8002 192.168.56.104:2675 N/A PT In Progress
192.168.64.25:3087 192.168.149.177:445 N/A PT Rjct Resources
192.168.64.31:1979 192.168.117.224:445 N/A PT Rjct Resources
192.168.64.31:1934 192.168.2.239:445 N/A PT Rjct Resources
192.168.16.20:2598 192.168.56.56:1296 N/A PT In Progress
192.168.16.30:139 192.168.55.184:3331 N/A PT Rjct Resources
192.168.65.5:1356 193.219.28.14:6666 N/A PT App Cfg
192.168.2.182:445 192.168.64.31:1995 N/A PT Rjct Resources
192.168.64.31:1915 192.168.214.73:445 N/A PT Rjct Resources
192.168.64.31:2020 192.168.201.141:445 N/A PT Rjct Resources
Can anybody tell why I have so many PT Rjct Resources and what does that mean
Regards/Asfar
Zach Seils
Level 11
Level 11
Syed,
The connection type "PT Rjct Resources" means that there are not enough free optimized connection resources to handle the connection.
If the sum total of active optimized connections + reserved optmized connections +
active auto-discovery connections hits the total maximum of optimized
connections supported by the WAE, any additional connections will go PT
Rjct Resources. If the active optimized connections are low, watch the
reserved connections and active auto-discovery connections. If reserved
connections are high, investigate MAPI AO. If active auto-discovery
connections are high, investigate why there are so many concurrent 3-way
handshakes going through the WAE.
Zach
Hi Zach
Can you please help me in telling the command for checking
Active optimize connections
Reserved Optimized Connections
Active Auto discovery connection
How to investigate MAPI AO
How to investigate concurrent 3 way hand-shake (Can it be because of any application behavior)
Hi Asfar,
The command 'show statistics connection' will give you a summary at the beginning of the output showing you the overall connection statistics for the device. To get more detailed statistics for the MAPI AO, you can use the command 'show statistics accelerator mapi'.
Zach
