Problem with REWRITE in Server, probe https
Dear Mister
I have a service, where the first conection is toward port 80 (HTTP). But, the client and Server negotiate, and start a service https (TLSV1).
What can I do for a probe function with this behavior??
I tried with a probe HTTP, but don't function. The Server is terminating the SSL .
I thing than probe HTTP can resolve this, but, what happens with the first conection http??
Best Regards
Gilles Dufour
what device ?
You could combine 2 probes.
One HTTP probe and one HTTPS probe.
Or just use the HTTP probe but if the server sends a redirect you need to set the loadbalancer to expect a 302 response.
Gilles.
Mister
The equipment is ACE 4710.
Is a rewrite, no redirect. The page change in the same server IP address. The first conection is HTTP, after that, the client negotiate a https conection,y stay functoning in that way.
Best Regards
you can't switch from http to https without some form of redirect.
You should take a sniffer trace to see what is going on.
Gilles.
Mister
You are rigth. This is the reply from the server:
HTTP/1.1 302 Found
Date: Tue, 15 Sep 2009 17:44:17 GMT
Server: IBM_HTTP_SERVER/1.3.28.1 Apache/1.3.28 (Win32)
Location: https://www.xxxxx.cl/script/demos/display_variables.jsp
Keep-Alive: timeout=15, max=100
Connection: Keep-Alive
Transfer-Encoding: chunked
Content-Type: text/html; charset=iso-8859-1
104
302 Found
Found
The document has moved https://www.xxxxx.cl/script/demos/display_variables.jsp">here.
I created a probe HTTP WITH code 302 like answer, but the probe is always inactive.
After that conection start a HTTPS conection.
Your suggestion would create two probes???
One HTTP and another HTTPS. Rigth??? Both probes must to be up for the service function. But, I had the same doubt before. I created a probe HTTP, with expect code 302, and not function. Is mandatory the another probe HTTPS for the first pone be up??
Best Regards
