WAAS FLOW MONITOR and NETQoS integration ( what ports do I open)
Hi there,
I am having issues integrating WAAS flow monitor feature with NetQoS in version 4.2.1.
The WAAS applicance fails to establish the initial session on port 778 with NetQoS which I believe it is needed to set the next session on port 9996 or 9995.
We have opened a "hole" for the WAE to register but still no go.
Any help will be appreciated..
Manuel
metalchic
The port used to communicate between the flow monitor and the NetQoS Aggregator and Management Console is TCP port 7878. You should be able to use the show commands on 4.2 to show the connection status. If the firewall is blocking that port, you'll want to punch a hole and it will continue to try to connect.
thanks lindi.
I believe the isusue may be related to an IPS and not a FW.
thanks
Manuel
