WAAS Inline Card Issue
adrien.dupont
Frequent Visitor
Frequent Visitor
Hello Everyone,
I have a question about Cisco WAAS (Wide Area Application Services).
We want to use the new WAVE-294, WAVE-594 and WAVE-694 in Inline mode (no wccp) We have several WAVE with WAVE-INLN-GE-4T included (by Cisco) in order to use the InlineGroup.
We have a problem with WAVE with no Inline card included. When we insert the card after the first boot, we have 4 GigabitEthernet port UP but no InlineGroup 1/0 and InlineGroup 1/1.
This is a correct configuration :
interface InlineGroup 1/0
 inline vlan all
 no autosense
 bandwidth 100
 full-duplex
 exit
interface InlineGroup 1/1
 inline vlan all
 no autosense
 bandwidth 100
 full-duplex
 exit
This is an incorrect configuration :
interface GigabitEthernet 1/0
 shutdown
 exit
interface GigabitEthernet 1/1
 shutdown
 exit
interface GigabitEthernet 1/2
 shutdown
 exit
interface GigabitEthernet 1/3
 shutdown
 exit
WAVE doesn't want to "create" the inlineGroup even if we reboot the device or write erase the configuration without the setup configuration.
The only way to configure the Inline Group is to
1 - remove the InlineCard
2 - write erase the startup-configuration
3 - boot the device
4 - use the Setup Wizard
5 - configure the rest of the configuration after the boot
Is it possible to avoid the long process ? I don't find a command to create these inlineGroup.
Thank you for your sollicitation
Adrien Dupont
Hi Adrien,
As per the installation guide : http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/wave/installation/594-694/guide/WAVE-594_HIG/594op2.html#91439
interface modules are not hot-swappable !
Best Regards
Finn
adrien.dupont
Frequent Visitor
Frequent Visitor
We tried again in this order :
1 - write erase without the card included
2 - shutdown the device
3 - insert the Inline-Card
4 - Boot the device
5 - Enter the commande "interception-method inline"
 And that's all. i think we have the problem when we hot-insert the card.
It's ok for us !
Adrien Dupont
Hi Adrien,
Best Regards
Finn
Rodrigo Octaviano
Frequent Visitor
Frequent Visitor
I'm unable to resolv this issue with those option. I just type: "inline enable" command and works! 😃
