WAAS - is possible to clear optimization statistics detail
ROMAN TOMASEK
I need clear these statistics in the WEB GUI. Is possible to clear them? I tried to use clear cache dre, clear statistics all - but without success. Thank you.
dstolt
Roman,
Go into System, Configuration, System Properties. Change System.monitoring.recordLimitDays to 0 and then change it back to the # of days you have set in your system (I usually just leave set to default). That should clear your stats.
Hope that helps,
Dan
dstolt
Roman,
Hope that helps,
Dan
Thank you very much!!! It is very simple;-)
thanks so much that's solve my problme too
