WAAS issue with McAfee EPO
c.walsh
Level 3
Level 3
Hi, we have a customer with WAAS deployed between 2 sites.
They currently have an issue with McAfee End Policy Orchestrator.
This is set up to run from a server at the HQ to a server at the remote site every hour.
When this runs, it hangs on some of the larger files.
If this is run with waas turned off, it works but takes a long time.
If the folder is copied manually (with waas turned on), it works.
Any ideas/help would be much appreciated.
Colin
Zach Seils
Level 7
Level 7
Any idea what protocol is used for the transfer?
Zach,
   This is a secure site & they haven't given us access yet to troubleshoot.
They do simulate this by manually copy & paste of the folder with the updates.
Will let you knowwhenwe get access
cheers
Colin
