WAAS Management
garry cordess
In a scenario where we use a WAAS appliance as a management box for the other WAAS's is there any reason why a small box i.e. WAVE-274 shouldn't be used to manage several big boxes i.e. WAVE-574?
Garry.
2 Accepted Solutions
John Gaskell
Level 4
Level 4
absolutely. In fact I would say that is the normal scenario. Even a small WAAS device can manage many large devices when in CM mode.
John
If this is hekpful, please mark as Answered or Helpful.
The official line (if you want support, etc) is a CM is essemtial.
If you just want to tinker with a couple of devices in a lab, and just love the commend line, then physically it would work without a CM. But it would be unsupported.
John
5 Replies 5
John Gaskell
Level 4
Level 4
John
Hi John,
Ok thanks that does sound like the right thing to do.
Many thanks,
Garry.
So having a management WAAS is essential or an option?
Garry.
John
Hi John,
Ok thought so, many thanks for the response.
Garry.
