Can you please advise us on what IOS code we should be using on our 2811 router to support WAAS and The HWIC -1FE module.
We were using the following code on our router and WAAS was working
c2800nm-advipservicesk9-mz.124-3c.bin
We needed to install a HWIC -1FE module in our 2811 router so we found the following code supported the module but now WAAS is not working
c2800nm-advipservicesk9-mz.124-11.XJ4.bin
Can you please advise us on the best possible code to use that will support the above.
