%WAAS-UNKNOWN-6-899999
sameer.shah
In WAE log we found below messages
config: %WAAS-UNKNOWN-6-899999: ReportCommandsAccounting: Report accounting after command is executed (logging host 10.11.4.20 priority information)
07-17-2011          16:15:08          User.Info          10.10.170.71          2011 Jul 17 16: config: %WAAS-UNKNOWN-6-899999: SendReport: Unknown Remote Host address due to console login.
07-17-2011          16:15:08          User.Info          10.10.170.71          2011 Jul 17 16: config: %WAAS-UNKNOWN-6-899999: ReportCommandsAccounting: Report accounting before command is executed (exit)
07-17-2011          16:15:09          User.Info          10.10.170.71          2011 Jul 17 16: config: %WAAS-UNKNOWN-6-899999: ReportCommandsAccounting: Reported an accounting to a remote server
07-17-2011          16:15:09          User.Info          10.10.170.71          2011 Jul 17 16: config: %WAAS-PARSER-6-350232: CLI_LOG log_cli_command: exit
07-17-2011          16:15:09          User.Info          10.10.170.71          2011 Jul 17 16: config: %WAAS-UNKNOWN-6-899999: ReportCommandsAccounting: Report accounting after command is executed (exit)
07-17-2011          16:15:09          User.Info          10.10.170.71          2011 Jul 17 16: config: %WAAS-UNKNOWN-6-899999: SendReport: Unknown Remote Host address due to console login.
07-17-2011          16:15:09          User.Info          10.10.170.71          2011 Jul 17 16: -exec: %WAAS-UNKNOWN-6-899999: ReportCommandsAccounting: Report accounting after command is executed (conf  t)
07-17-2011          16:15:09          User.Info          10.10.170.71          2011 Jul 17 16: -exec: %WAAS-UNKNOWN-6-899999: SendReport: Unknown Remote Host address due to console login.
07-17-2011          16:15:10          User.Info          10.10.170.71          2011 Jul 17 16: -exec: %WAAS-UNKNOWN-6-899999: ReportCommandsAccounting: Report accounting before command is executed (wr)
07-17-2011          16:15:10          User.Info          10.10.170.71          2011 Jul 17 16: -exec: %WAAS-UNKNOWN-6-899999: SendReport: Unknown Remote Host address due to console login.
07-17-2011          16:15:10          User.Info          10.10.170.71          2011 Jul 17 16: -exec: %WAAS-UNKNOWN-6-899999: ReportCommandsAccounting: Reported an accounting to a remote server
07-17-2011          16:15:10          User.Info          10.10.170.71          2011 Jul 17 16: -exec: %WAAS-PARSER-6-350232: CLI_LOG log_cli_command: wr
07-17-2011          16:15:10          User.Info          10.10.170.71          2011 Jul 17 16: sshd: %WAAS-UNKNOWN-6-899999: ReportExecAccounting
07-17-2011          16:15:10          User.Info          10.10.170.71          2011 Jul 17 16: sshd: %WAAS-UNKNOWN-6-899999: Report exec shell accounting after command is executed
What these means?
Is there any unknown user trying to execute some commands? The same is reflecting as security warning in TACACS reports.
Sameer Shah
Bhavin Yadav
Hi Sameer,
What is this ip address in logs: 10.10.170.71?
Further, can you also post the sh ver output from WAAS?
Regards.
