WAAS WCCP help
darkid123
Community Member
Hi guys,
Please have a look at my topology attached.Right now this is what I have configured on the core:
ip wccp 61
ip wccp 62
int vlan 151
ip wccp 61 redirect in
int vlan 173
ip wccp 62 redirect in
The same is configured on the branch office with the appropriate vlans.
Whatever I do, the "total packets redirected" count never seems to increase. I tried turning on ip wccp 62 redirect out on vlan 173, and ip wccp 61 redirect in on the same vlan, but then only the count for service 61 goes up.
Also, should I use access-lists to permit redirection only to branch offices that have a WAE? If I don't use a redirect-list, shouldn't all packets be redirected to the WAE, and then the WAE would decide whether to optimize or not based on if there's another WAE at the endpoint location?
Here's an output of "sh ip wccp 61 detail"
WCCP Cache-Engine information:
Web Cache ID: x.x.x.x
Protocol Version: 2.0
State: Usable
Redirection: L2
Packet Return: GRE
Packets Redirected: 0
Connect Time: 00:51:22
Assignment: MASK
Any help is greatly appreciated.
The 3560 and the 3750 need to use the sdm templetes that have routing enabled.
sdm prefer routing
THen reload the box and it should start working.
Hope that helps,
Dan
10 Replies 10
cfolkerts
Level 4
Level 4
Since you are performing L2 rewrite under WCCP, you will not see the packets redirected increase. The redirection is handled by hardware instead of software. If redirection was done on a router, you would see packet increases.
I have had WAAS in place for about a year now and you can see below that I have only redirected 2 packets. I am redirecting on a 6509 as well.
mp1swcr01#show ip wccp 61
Global WCCP information:
Router information:
Router Identifier:
Service Identifier: 61
Number of Cache Engines: 2
Number of routers: 2
Total Packets Redirected: 2
Redirect access-list: WAAS_61
Total Packets Denied Redirect: 9179
Total Packets Unassigned: 186
Group access-list: -none-
Total Messages Denied to Group: 0
Total Authentication failures: 0
Thanks a lot for your reply.
So what would be the way to verify everything is working properly then?
I'm guessing the following command on the WAE with increasing packets on the "Transparent non-GRE packets received"?
WAAS#sh wccp gre
Transparent GRE packets received: 0
Transparent non-GRE packets received: 1778
There's no way to tell directly on the switch if packets are being redirected properly?
Thanks again.
First verify all routers are being seen from the WAE
perform a show wccp routers
to verify if packets are being redirected to wae
show stat dre
show stat tfo
show stat cifs
Ok thanks.
I see now that there's traffic being redirected from the 6509's to the WAE at 2 offices. However, the third branch has a 3560 doing the redirection, and I can't get any packets to redirect. The WCCP peering shows up as good/usuable however.
I'm using l2-redirect & l2-return with mask assign. (wccp tcp-promiscuous router-list-num 1 l2-redirect mask-assign l2-return)
Is there any other config that should be different on the 3560?
Thanks!
if you post the configs, I will check them for you.
also 3560 minimum IOS for wccp is 12.2(46)SE
Aha.
Gotcha.
I'm running:12.2(44)SE2.
XCDSKPA0001#sh ver
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(44)SE2, RELEASE SOFTWARE (fc2)
I will load the new code tonight and hopefully it will solve my problem.
If not i'll post the configs later.
Thanks so much for your help.
No problem, helps me learn as well.
Let me know how you make out,
I am attaching minimum IOS for WCCP across all platforms for WAAS
Ok I updated the code. I'm now running:Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
However, it's still not redirecting any packets.
This is the config I have on the 3560:
ip wccp 61
ip wccp 62
interface Vlan16 //WAN
ip address 192.168.16.253 255.255.255.0
interface Vlan15 //LAN
ip address 192.168.15.254 255.255.255.0
interface Vlan21 //WAE Subnet
ip address 192.168.21.254 255.255.255.0
and on the WAE:
interface GigabitEthernet 1/0
ip address 192.168.21.1 255.255.255.0
ip default-gateway 192.168.21.254
wccp router-list 1 192.168.21.254
wccp version 2 // I also tried with l2-return
I've attached a few outputs...
Thanks.
sdm prefer routing
Hope that helps,
Dan
darkid123
Community Member
Nice!
That worked!
Thanks again for all your help...
