WAE 512 and problem with services
Tomasz Mowinski
Level 2
Level 2
I have few WAE 512 installed in my network. Every use 4.1.5b software. I have problem with one. I have upgraded it from CD and after that I see below alarms:
Directy after WAE restart appear:
Major: DRE (DRE+LZ) initialization failed: <>
after about 15 minutes other alarms appear:
Critical: nodemgr: The wafs_edge service has been disabled.
Critical: Edge is down.
Do you know where should I look for a problem source ?
Thanks in advance
James
devsharma
Level 2
Level 2
James,
What is the output of show disk details command? There could be a possibility that the file systems are not functional and also the code is corrupt.
Dev
Here you are the outpu:
ps. after 3 days these alarms disapeard. When I've restarted WAE alarm appeared and after 3 days desapered again....
Physical disk information:
  disk00: Present    5QD39305   (h02 c00 i00 l00 - Int DAS-SATA)
          715402MB(698.6GB)
  disk01: Present    5QD392VR   (h02 c00 i01 l00 - Int DAS-SATA)
          715402MB(698.6GB)
Mounted file systems:
MOUNT POINT      TYPE       DEVICE                SIZE     INUSE      FREE USE%
/sw              internal   /dev/md0             991MB     914MB      77MB  92%
/swstore         internal   /dev/md1             991MB     880MB     111MB  88%
/state           internal   /dev/md2            5951MB     256MB    5695MB   4%
/local/local1    SYSFS      /dev/md5           14878MB    1277MB   13601MB   8%
/disk00-04       CONTENT    /dev/md4          668196MB  119653MB  548543MB  17%
.../local1/spool PRINTSPOOL /dev/md6             991MB      16MB     975MB   1%
Software RAID devices:
  DEVICE NAME  TYPE     STATUS                PHYSICAL DEVICES AND STATUS
  /dev/md0     RAID-1   NORMAL OPERATION      disk00/00[GOOD]  disk01/00[GOOD]
  /dev/md1     RAID-1   NORMAL OPERATION      disk00/01[GOOD]  disk01/01[GOOD]
  /dev/md2     RAID-1   NORMAL OPERATION      disk00/02[GOOD]  disk01/02[GOOD]
  /dev/md3     RAID-1   NORMAL OPERATION      disk00/03[GOOD]  disk01/03[GOOD]
  /dev/md4     RAID-1   NORMAL OPERATION      disk00/04[GOOD]  disk01/04[GOOD]
  /dev/md5     RAID-1   NORMAL OPERATION      disk00/05[GOOD]  disk01/05[GOOD]
  /dev/md6     RAID-1   NORMAL OPERATION      disk00/06[GOOD]  disk01/06[GOOD]
Disk encryption feature is disabled.
regards
James
