WAE Farm Best Practice Return Method
james.robinson
Community Member
                  This document is recommending, for a 6500 with Sup720 PFC 3B, Layer2 redirection and return:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-629052.html
Question: Is this best practice for return from a 7 WAE farm to this switch?
Nicolas Fournier
Hi James,
As long as your WAEs are L2 adjacents to your switches, it is indeed the recommended setting.
Even if the SUP720 should handle GRE redirect in hardware, the return is still handled in software so if you use it as forwarding method, you can easily bring your catalyst down with it.
Nicolas
