WAE, how to control load share with WCCP
jason_majie
Hi All:
I have attached a simply diagram here, basically, in core area, i have two routers and one big WAE appliance; at the edge area, i have two routers and two small WAE appliances.
at most of the time, the traffics are asymetric. (please see the red broken arrow line in the attached file). i have enabled WCCP on the four routers, i want to ask: how to controll the WCCP load balance to make sure traffic going out from the same user and come back will always go through the same WAE at the edge site, which means the traffic going out and return will via the same pair of WAE, so the optimization will happen.
thanks
2 Accepted Solutions
The WCCP database is replicated across both routers therefore asymetrical routing is NOT an issue.
Jason,
The two edge routers will have the same WCCP Hash or Mask buckets which will determine which WAE to send the traffic to.
Assuming you are using software based routers at the edge and you've configured the default of Hash assignment on the edge WAEs you could use the following command on the routers to see where specific hosts will be sent based on the hash calculation.
show ip wccp hash <dst-ip> <src-ip> <dst-port> <src-port>
Here is a sample output from my lab with two WAEs and two Routers (2821 and 2911):
########### Router1 #######################
pdi-2821-rtp#sh ip wccp 61 det
WCCP Client information:
WCCP Client ID:          14.110.3.130
Protocol Version:        2.0
State:                   Usable
Redirection:             GRE
Packet Return:           GRE
Assignment:              HASH
Initial Hash Info:       00000000000000000000000000000000
Assigned Hash Info:      FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Hash Allotment:          128 (50.00%)
Packets s/w Redirected:  14
Connect Time:            00:01:10
Bypassed Packets
  Process:               0
  CEF:                   0
  Errors:                0
WCCP Client ID:          14.110.3.131
State:                   Usable
Redirection:             GRE
Packet Return:           GRE
Assignment:              HASH
Assigned Hash Info:      00000000000000000000000000000000
Packets s/w Redirected:  0
Connect Time:            00:00:25
Bypassed Packets
  Process:               0
  CEF:                   0
  Errors:                0
pdi-2821-rtp#sh ip wccp 61 hash 0.0.0.0 14.110.3.117 0 0
WCCP hash information for:
    Primary Hash:   Src IP: 14.110.3.117
Bucket:  22
    WCCP Client: 14.110.3.131
pdi-2821-rtp#sh ip wccp 62 hash 14.110.3.117 0.0.0.0 0 0
    Primary Hash:   Dst IP: 14.110.3.117
Bucket:  22
########### Router 2 #######################
pdi-2911-beta-rtp#sh ip wccp 61 det
State:                   Usable
Redirection:             GRE
Packet Return:           GRE
Assignment:              HASH
Initial Hash Info:       FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Connect Time:            00:02:11
GRE Bypassed Packets
  Process:               0
  CEF:                   0
  Errors:                0
State:                   Usable
Redirection:             GRE
Packet Return:           GRE
Assignment:              HASH
Connect Time:            00:02:10
  Process:               0
  CEF:                   0
  Errors:                0
pdi-2911-beta-rtp#sh ip wccp 61 hash 0.0.0.0 14.110.3.117 0 0
Bucket:  22
pdi-2911-beta-rtp#sh ip wccp 62 hash 14.110.3.117 0.0.0.0 0 0
Bucket:  22
Hope this helps clarify things.
Mike Korenbaum
Cisco WAAS PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
jason_majie
the diagram here.
Jason,
State:                   Usable
Redirection:             GRE
Packet Return:           GRE
Assignment:              HASH
Bypassed Packets
  Process:               0
  CEF:                   0
  Errors:                0
State:                   Usable
Redirection:             GRE
Packet Return:           GRE
Assignment:              HASH
Bypassed Packets
  Process:               0
  CEF:                   0
  Errors:                0
Bucket:  22
Bucket:  22
State:                   Usable
Redirection:             GRE
Packet Return:           GRE
Assignment:              HASH
  Process:               0
  CEF:                   0
  Errors:                0
State:                   Usable
Redirection:             GRE
Packet Return:           GRE
Assignment:              HASH
  Process:               0
  CEF:                   0
  Errors:                0
Bucket:  22
Bucket:  22
Mike Korenbaum
thanks a lot.
