wae512 disk replacement
Kashish_Patel
Level 6
Level 6
Can somebody tell me what is the procedure of replacing a faulty disk on WAE512?
As WAE512 does not support hot swap functionality, so I think this should be done:
  • Physically power off the device
  • take out faulty disk
  • insert new disk
  • power on the device
Could somebody please confirm this? I did not find the exact replacement procedure for wae512 on cisco.com. Doc talks about wae612, but not wae512.
John Peek
Level 2
Level 2
This document does discuss the WAE 512. And yes you are correct you will need to power down the device.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/wae/installation/512/612/guide/9137spar.html#wp1036726
