WAF - how to import SSL chain
Martin Kyrc
Level 3
Level 3
hello,
I have configured http service on WAF. It works. Now I need configure it as https. I will terminate SSL on WAF, and communication to real server is only http - no problem with this, it 'works'.
There is one problem. My SSL cert for service is published by verisign. My question is, how can I import full SSL chain (cert for my service + two verisign cert for CA)? I have it in one file, but after import this file + private key, client browser show not full SSL chain (it shows only my cert, not two verisign cert).
fyi: the same certificate is applied on linux machine and there is no problem with it.
I tried import this two verisign cert as "Trusted Certificate Authorities", but it was not successful.
any ideas?
Hi Martin,
Did you resolve your problem ? I has the same problem with you and don't have a way to resolve this. How to import certificate and private key for ACE-WAF ?
Anyone can help me to resolve this problem?
Trung.
