WAVE 694 Inline port WAN/LAN reassignment.
Goga
Hello everyone!
Is it possible to change inline ports wan/lan assignments in inline group on WAVE 694/WAVE 7571 with 4/8 port copper gigabit ethernet inline module through telnet or Central Manager?
Can any problems occur if cords were plugged in wrong ports (from local switch to inlineport wan (inlinegroup 1/0 0) ; from ISP provider to inlineport lan (inlinegroup 1/0 1)?
lveloso11
Hi Igor,
As far as I remember it doesn't really matter where you connect the WAN and LAN cable, if the card is in inline mode.
Leo
lveloso11
Hi Igor,
Leo
