WAVE574 replacement of PCI CARD
lorenzo limardo
I have a WAVE574 whose card PCI is broken.
Can i use any PCI EXPRESS 10 G CARD, or is something special in It?
Reading this document, any should be good.
Is there a list of compatible cards maybe?
General Technical Specifications
Interface standard PCI-Express Base Specification Revision 1.0
Size PCI Short add in card: 6.6 × 4.4 in. (167.6 × 111.2 mm)
PCI Express card type ×4
This card is impossible to find.
PE2G2BPI80
Dual Ports Copper Gigabit Ethernet PCI Express Bypass Server Adapter Intel® 82580DB Based
Thanks a lot for the help.
The WAVE-574 can accommodate one optional 2-port Gigabit Ethernet inline network adapter or one optional 4-port Gigabit Ethernet inline network adapter.
For information about the features of the Cisco WAVE Inline Network Adapter and its cabling requirements, see Chapter 5, "WAVE Inline Network Adapter."
To install a PCI adapter in the riser-card assembly, follow these steps:
Please refer the link for more details:-
https://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/wave/installation/574/guide/WAVE-574_HIG/574op2.html
Thanks a lot for the answer, i desume any PCI adapter may be good, there is not a spec brand recommened.
as long as 4 ports.
Inline Network Adapter Description
The WAVE appliance supports one optional 2-port Gigabit Ethernet inline network adapter or one optional 4-port Gigabit Ethernet inline network adapter. The inline network adapter is a full-height, three-quarter-length PCI Express network interface card that contains two or four independent Gigabit Ethernet ports. (See Figure 5-1.)
Figure 5-1 4-Port Inline Network Adapter
The Cisco WAVE inline network adapter provides an inline traffic interception capability for your appliance. When you configure the WAVE appliance for inline interception mode, you can set attributes to control which interfaces are to be used over which VLANs. By default, the adapter operates on all inline-capable interfaces and VLANs. You can configure the inline redirection feature using the WAAS CLI or the WAAS Central Manager GUI.
