WCCP and VRF
paul.matthews
Level 10
Level 10
I am struggling to see a clear statement of VRF awareness for WCCP in 12.4(T). I have seen comments on here that WCCP is not VRF aware, but the documentation for 12.4(T) makes no reference to VRF awareness. Does anyone know if WCCP is VRF aware yet, and just as importantly, has anyone got a reference we can point people to?
Paul
dstolt
Paul,
The VRF awareness for 12.4(T) is still probably 8-12 months out. VRF aware WCCP features are definitely in the pipeline, but nothing has been publically published on availability timelines.
Dan
Dan, thanks for the reply - are you aware of any references that say WCCP isn't VRF aware? I found one but it was platform specific for the 3750.
Paul.
Paul,
It's now publically available on the forum... but you are correct, I've only found it on the 3750 and 3550 documentation.
Dan
at the 3750 you will need to place the redirect statement on each of the VLANs, ip wccp 61 redirect in
Kindly find here GRE Tunnel with VRF Configuration Example:
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_configuration_example09186a00801e1294.shtml
I have gotten as far as the WAE registering the router:
"WCCP configuration for TCP Promiscuous service 61 and 62 succeeded.
WCCP configuration for TCP Promiscuous succeeded.Please remember to
configure WCCP service 61 and 62 on the corresponding router."
wae01#sh wccp router
Router Information for Service: TCP Promiscuous 61
Routers Configured and Seeing this Wide Area Engine(1)
Router Id Sent To Recv ID
0.0.0.0 209.1.1.1 0000022F
The router registers the WAE as a WCCP client:
router04#
"*Feb 4 18:56:09.892: %WCCP-5-SERVICEFOUND: Service 61 acquired on WCCP
client 209.1.1.2"
"*Feb 4 18:56:09.892: %WCCP-5-SERVICEFOUND: Service 62 acquired on WCCP
client 209.1.1.2"
The router however cannot figure out what its ID is and does not see
itself as a WCCP group router.
router04#sh ip wccp
Global WCCP information:
Router information:
Router Identifier: -not yet determined-
Protocol Version: 2.0
Service Identifier: 61
Number of Service Group Clients: 1
Number of Service Group Routers: 0
Total Packets s/w Redirected: 0
Process: 0
Fast: 0
CEF: 0
Redirect access-list: ACCELERATED-TRAFFIC
Total Packets Denied Redirect: 0
Total Packets Unassigned: 25957
Group access-list: -none-
Total Messages Denied to Group: 0
Total Authentication failures: 0
Total Bypassed Packets Received: 0
This is a short summary of important commands for working with VRF's.
View the VRF instances and the associated interfaces.
ml-mr-c6-gs#show ip vrf
Name Default RD Interfaces
blurvrf 100:2 Vlan215
Vlan326
tgvrf 100:1 Vlan132
Vlan325
TenGigabitEthernet1/1
ml-mr-c6-gs#
Show the routing table for a specific VRF.
ml-mr-c6-gs#show ip route vrf tgvrf
Routing Table: tgvrf
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external,
---More--
Gateway of last resort is 128.117.243.57 to network 0.0.0.0
O E2 192.52.106.0/24 [110/1] via 128.117.243.57, 1d19h, Vlan325
O E2 192.168.150.0/24 [110/160] via 128.117.243.57, 1d19h, Vlan325
172.17.0.0/29 is subnetted, 3 subnets
O E2 172.17.1.16 [110/0] via 128.117.243.57, 1d19h, Vlan325
O E2 172.17.1.8 [110/1] via 128.117.243.57, 1d19h, Vlan325
O E2 172.17.1.0 [110/1] via 128.117.243.57, 1d19h, Vlan325
--More--
Debugging should otherwise be similar to a regular switch or router.
Final Teragrid VRF Design and Diagrams
http://www.cisl.ucar.edu/nets/devices/routers/cisco/vrf/final.shtml
Teragrid Testbed Design
http://www.cisl.ucar.edu/nets/devices/routers/cisco/vrf/testbed.shtml
Cisco 4500 Series Switch Cisco IOS s/w config guide 12.1(20)EW
Configuring VRF-Lite
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/20ew/configuration/guide/vrf.html
sachin garg
