WCCP on Cisco 6500 with SUP720
CSCO11177789
Hi;
Could i configure wccp on cisco 6500 for integration with websense ?
if answer is yes, could you give me a simple example ?
Ios ver : Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXH3
thanks.
dstolt
Yes,
You can definitely configure WCCP on the 6500 with the SUP720 running SXH. The wccp global server needs to be configured on the router and then you need to configure redirection on an interfaces. However, most of the WCCP configurations are controlled by the WCCP client, in your case the websense server. Unfortunately I don't have a websence configuration for you, but I've put the 6500 info below.
An overview of WCCP on the 6500 running SXH is here: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/wccp.html
However, some rules of thumb to keep your processing of traffic in hardware on the 6500 are as follows..
- Both GRE and L2 redirect are supported
- Use Mask assign.
- Use Redirect-in on your interfaces.
So on the 6500, you will be configuring you global wccp service:
ip wccp web-cache
and on the appropriate interfaces, you will configure the interception:
(config-if)# ip wccp web-cache redirect in
Hope that gives you some pointers...
Dan
