What Cache contents
allenm
Small simple question, what files types will a ce-500 series cache. I am looking in particular to find out if pdf files will be cached in the ce-500s.
Allen
jfoerster
Level 4
Level 4
Hello Allen,
I see no reason why pdf's shouldn't be cached by the CE if they are requested via HTTP. If you do ftp over HTTP there might be an issue but as mentioned above I see no reason why they shouldn't be cached. The only thing I could imagine is the fact, that you deny to chache pdf via a rule but I guess that this is not your goal.
Another problem might be that the PDF is linked in an ASP or something like that and is refered in different ways so that the CE could not identify that this is the same PDF which is alredy present at the CE.
Hope that helped...
Joerg
