When does a sticky entry get removed on CSM
tporembski
I have one sticky group for multiple vservers and within each vserver is a different serverfarm with the same IPs but each server farm has a different probe.  Now if you look in the sticky table there will  be only once entry if my sticky is by source IP.  My question is if the probe on one of those serverfarms fails taking down a particular server will that server's entry be removed from the sticky table?
And does this function the same way on an ACE as it does on a CSM?
Thank you
Tony.
mwinnett
Level 3
Level 3
Tony, can you share the relevant parts of your config, please ? Matthew
tporembski
see attached
Tony, the failure of a probe (or even all probes for a real) does not delete a sticky entry. However, when a connection request is made that invokes the sticky, and the real is not operational, then the sticky entry is deleted. I can't seem to gte into my ace to test, but I would expect it to be similar. Matthew
