when I issue the 'Force group Settings' command what effect will this have on existing flows? Do I need to disable WCCP prior to issuing this command on the affected WAE's?
Shankar K
Hi WAAS Experts,
I have a query, when I issue the 'Force group Settings' command what effect will this have on existing flows? Do I need to disable WCCP prior to issuing this command on the affected WAE's?
Shankar K
Nicolas Fournier
Hi Shankar,
A change of classifier/policy on the WAE is not affecting the existing flows so you shouldn't need to disable WCCP if you want to force group settings there.
Nicolas
