Wrong Load reporting via KAL-AP form CSM to GSS
yves.haemmerli
When multiple virtual servers are configured on the same VIP (each using another TCP port), the CSM averages all the CAPP load values when reporting the final CAPP load to the GSS.
Unfortunately, when a redirect vserver is configured on the same VIP (i.e to redirect the user to another TCP port), the CAPP load value sent to the GSS is wrong. This is due to the fact that the redirection vserver has always a load value of 2! Therefore, even if all real servers of the server farm are down, the reported load value to the GSS is (255 + 2) / 2 = 128 instead of 255 (offline).
Why does the CSM take a redirection server farm into account when reporting the load value to the GSS ? What would be a work-around ?
Here is an extract of my configuration:
serverfarm REDIRECTION
nat server
no nat client
redirect-vserver REDIR-1
webhost relocation 10.10.10.111:26000/irj
inservice
serverfarm PORTAL
nat server
nat client NAT-MSSRTE
real 10.10.10.10
maxconns 200
minconns 100
inservice
real 10.10.10.11
maxconns 200
minconns 100
inservice
policy PORTAL-POLICY
sticky-group 1
serverfarm M-GLOBEPROD
policy REDIR-POLICY
url-map URL-1
vserver PORTAL-VSERVER
virtual 141.122.88.87 tcp 26000
persistent rebalance
slb-policy PORTAL-POLICY
no inservice
vserver REDIRECT
virtual 141.122.88.87 tcp www
slb-policy REDIR-POLICY
inservice
Yves,
the command is under the vserver and I believe it is 'domain '.
Gilles.
Gilles Dufour
you should use kal-ap by tag instead of kal-ap by vip.
This will allow you to really select which vserver you want the load from.
Gilles.
Hi Gilles,
Thank you for your suggestion. I configured KAL-AP by Tag now, but the two VIP answers configured on the GSS remain in offline state. I didn't found any description on how to configure the counterpart tag string in the CSM vserver configuration (I suppose that the same tag must be configured on the GSS and on the CSM ?)
Can you help me ?
Yves,
Gilles.
Gilles,
Thank you very much for your support, it works now with the command Router(config-slb-vserver)# domain . May I suggest a GSS/CSM documentation improvement, in which more details could be given on the communication between the GSS and the CSM. In particular the usage of KAL-AP by VIP versus KAL-AP by Tag.
Thanks again
Yves
