x-forwarded-proto , it is possible on ACE ?
gianluca811
referring to the previously request   https://supportforums.cisco.com/discussion/12346961/ace-ssl-terminator-doesnt-work#comment-10063251
brefly:
Public IP 22.235.121.6 port 80 --> balanced on 192.168.250.165-166 on port 8889
Public IP 22.235.121.6 port 443 --> my ace terminate ssl and balance the traffic in clear text to 192.168.250.165-166 on port 8889
The sysadmin added a new problem:
the real server now receive all packets in http, it is possible configure the x-forwarded-proto on the LB so the real server is able to understand if a request is originated from http or https ?
I didn't find official document on Cisco Ace documentation, can anyone help me ?
Kanwaljeet Singh
You can use the x-forwarded-proto on L7 policy map:
Admin(config-pmap-lb-c)# insert-http X-Forwarded-Proto header-value "%pd"
or create an action list and associate action list with policy:
 header insert request X-Forwarded-Proto header-value “%pd”
%is is for client IP, similary you can add source port as well.
Kanwal
Note: Please mark answers if they are helpful.
Kanwaljeet Singh
Kanwal
it's working thanks, but the real server receive now port 443, this is a problem from application point of view that should receive https.
In the end:
It is possible send to the real server https instead of 443 ?
I didn't get the question? The x-fwd-proto will send the original destination port on which client came and that was your requirement or something else?
Kanwal
my sysadmin rised this concern. In the x-fwd-proto header instead of put 443, it is possible put https?
I don't know the application on the server how work, but this is the request, look like a bit wired, I know. Anyway I can say it is not possible change 443 with https, because from Network point of view doesn't make sense.
