Check for firmware upgrades doesn't
jrengel
It just errors out with "Some errors happened - Check again."
Last checked and latest image fields do not populate
Cisco account credentials are good.  We can manually download the firmware.
Joe
Brandon Turpin
Hi Joe,
What firmware version were you on when this was seen?  If you navigate away from the Firmware screen and go back, are the 'Last Checked' and 'Latest Image Available' fields populated?  Do you always see the message 'Some errors happened - Check again' when you press the 'Check Now' button?
Brandon
