04-25-2011 11:15 PM
Any reason NSS 324 (FW 1.3) and ESW-540-8P (FW 2.1.19) are not properly identified in the network ?
Solved! Go to Solution.
04-26-2011 06:54 AM
Connect it t the ESW directly and not the SA. The SA is not supported on the version that you are running.
Marcos
04-26-2011 06:39 AM
Greg,
Double click on the ESW and make sure you provide credentials to access it in order to have proper discovery of CDP neighbors. The switch itself should have been recognized via CDP by the appliance if it is directly connected to it. What customer ID is this?
Marcos
04-26-2011 06:46 AM
The thunderbolt device is connected to an SA500 which the ESW also connected. I've provided all credentials. It will backup and intereact, but it did not indicate the device type or icon. Just generic Cisco.
It's customer 1492
04-26-2011 06:54 AM
Marcos
04-26-2011 07:43 AM
Bummer
Thanks! I will try that.
