DHCP issue with v1.0.3.4
linksysinfo
Level 4
Level 4
came home from work this evening and main pc could not get an IP.  was setup to pick up automatically by DHCP. connected via LAN. reboot didn't help
I have now reverted back to 1.0.2.4 as this 3.4 seems very buggy.
who actually does the programming for the RV220W Firmware? is it Cisco or TeamF1 ?
Regards Simon
5 Replies 5
ddiep
Level 4
Level 4
Simon,
Sorry that I've been busy and thus my response had been slow lately. We could not recreate aformentioned dhcp issue.Please elaborate and provide us w/ more details:
1. Is your main pc connected via wire or wifi?
2. Is it happen to many other devices or just 1 main pc?
3. You mentioned reboot didnt help. Is router or pc rebooted?
4. please send me your config (via email) file.
5. if possible,  can you try again w/ 1.0.3.4?
Don
1. Wired @ 1Gbps.
2. just teh main PC as far as I could tell.
3. both rebooted.
4. config will be emailed and admin pwd will follow.
5. I am now on 1.0.3.4 as requested.
Simon
Regards Simon
Simon,
a quick question: After upgrade to 1.0.3.4, did problem persisted on main pc? if yes and if possible,  please send us wireshark trace of its dhcp request packets. Perhaps there is something in it that the router didn't like and could not process.
Btw, thanks for config file.
Don
at present, i'm heading for bed, but the DHCP issue is not here.  when it happened the first time it was approx 24hrs after the upgrade.  i had come home and tunred the PC on and got nothing.
i'll monitor the situation again.
Regards Simon
Duly noted. We also continue to monitor on our side.
