Firmware upgrade warnings
Brian Bergin
Level 4
Level 4
I've gotten a few of these lately.
Customer NameTerabyte Computers, Inc.
Error EventDevice: Firmware upgrade
Event Date/Time2012-05-07 03:37
DeviceHostname: PLG1000
IP Address: 192.168.100.146
MAC Address: F0:AD:4E:00:0B:F2
Thoughts?
jamwyatt
Hi Brian,
It looks like a reboot cleared something and the device upgraded. We have security measures that are reset on a reboot and that might be fixed things. I did run a 'showtech' operation that gives us operational details and I found that it came through at 2 bytes in size (totally wrong). Post the reboot, the showtech now contains content and I'll see if that can point to the issue for us to fix.
Robert
jamwyatt
Hi Brian,
I'm checking into this at the moment. You might notice a device reboot in the process.
Robert
jamwyatt
Hi Brian,
Robert
Thanks...  Let me know if you need anything else.
Brian,
Just a little update. We've found what we believe to be the issue and we're preparing a fix. It isn't clear exactly when the fix will hit the field, but the issue does clear with a reboot for now and only affects old installations. I've been monitoring your system for any progression back into the bad state and it appears to be stablized.
Robert
