SmallNetBuilder review of RV220W
linksysinfo
Level 4
Level 4
jay.johnson1
Yeah...
I just checked it out today finally.  As far as I can see, the router is handling business.  There was an individual on DSLreports bagging on the 220w because "2" people were having problems :-)  Check it out if you haven't seen it:
1) https://supportforums.cisco.com/message/3301160
2) https://supportforums.cisco.com/message/3281290
I remember when Simon and I got our WRV200's and I couldn't for the life of me figure out why his IPSEC tunnels "just worked" and mine didn't.  Come to find out, Simon had an "NTL" cable modem connection (DHCP) and I was running a "Hi-Velocity" ADSL connection (Static).  As a result, once I set my WRV200 to "static" all my vpn tunnels started working :-)
Jay
Certified: CCNA (R/S, Security, Voice), CCDA, CCNP (R/S)
Thanks guys for the reviews. I guessed RV220W performs pretty well.  So far , so good....
Full review has now been done.
http://www.smallnetbuilder.com/wireless/wireless-reviews/31456-cisco-rv220w-wireless-network-security-firewall-reviewed
Notes:
ProductCisco Wireless Network Security Firewall (RV 220W)
SummarySmall-biz dual-band N router with 10/100/1000 ports and SSL, IPsec and PPTP VPN
Pros• SSL, IPsec, PPTP VPN
• > 700 Mbps routing throughput
• Gigabit ports with jumbo frames
• Dual band N radio
• IPv6 support
Cons Undistinguished wireless performance
• Slow reboots
• A few odd menu organization choice
s
Regards Simon
