01-28-2016 07:09 AM
I'm trying to list a user's VMs. I'm accessing the CUMI api using administrator at this URL
https://IP/vmrest/mailbox/folders/inbox/messages?userobjectid=05540dce-da09-4219-8e85-137964db05c7
But I'm getting this error:
User does not have root message access: 9b5126fb-38e9-4469-9680-43bd33f9d6bb
Solved! Go to Solution.
01-29-2016 06:37 AM
does the administrator account you're authenticating as have the "Mailbox Access Delegate Account" role? If not you need it - that gives you rights to other user's mailboxes - by default even admin accounts that have access to the directory do not get to see other user's mailboxes.
if it does, let us know what version of Connection you're on - I just tried that same command on a 10.0 installation (with an account that had the delegate access role) and it worked ok.
01-29-2016 06:37 AM
01-29-2016 10:05 AM
Thanks for the reply we were able to get what we needed by adding the "Remote Administrator" role in Unity.
