CiscoIPPhoneExecute - NavDown and VolDown are not accepted
icarg2019
I am trying to send key presses to remote phones using the CiscoIPPhoneExecute POST method. My code works perfectly, I can send all commands except NavDown.
I can successfully send NavUp key press:
<?xml version="1.0" encoding="utf-8"?>
<CiscoIPPhoneResponse>
<ResponseItem URL="Key:NavUp" Data="Success" Status="0" />
</CiscoIPPhoneResponse>
NavDown key press produces an error:
<ResponseItem URL="Key:NavDown" Data="URI not found" Status="6" />
Looking at the XML schema file in the phone application development notes, NavDown is a supported key. Tested on both 79xx and 88xx phones, including the latest firmware version.
Same issue for VolUp (works fine) and VolDown (throws an error)
I can only assume that there is a bug in the code.
dstaudt
Looking at the latest dev notes, it looks like those keys are 'VolDwn' and 'NavDwn' (note the lack of an extraneous 'o')...can you check?
dstaudt
You are right. These are the correct keys. I was looking in the wrong section of the documentation (under XML schema), I see now there is a Device Control URIs section that has the correct information.
