03-01-2019 01:27 AM
I am trying to send key presses to remote phones using the CiscoIPPhoneExecute POST method. My code works perfectly, I can send all commands except NavDown.
I can successfully send NavUp key press:
<?xml version="1.0" encoding="utf-8"?>
<CiscoIPPhoneResponse>
<ResponseItem URL="Key:NavUp" Data="Success" Status="0" />
</CiscoIPPhoneResponse>
NavDown key press produces an error:
<ResponseItem URL="Key:NavDown" Data="URI not found" Status="6" />
Looking at the XML schema file in the phone application development notes, NavDown is a supported key. Tested on both 79xx and 88xx phones, including the latest firmware version.
Same issue for VolUp (works fine) and VolDown (throws an error)
I can only assume that there is a bug in the code.
Solved! Go to Solution.
03-01-2019 12:31 PM
Looking at the latest dev notes, it looks like those keys are 'VolDwn' and 'NavDwn' (note the lack of an extraneous 'o')...can you check?
03-01-2019 12:31 PM
03-02-2019 02:33 PM - edited 03-02-2019 02:44 PM
You are right. These are the correct keys. I was looking in the wrong section of the documentation (under XML schema), I see now there is a Device Control URIs section that has the correct information.
