Enable WebGL for webex board 70s
seankin
We are experimenting with the web apps and macros, is it possible to enable WebGL on the board for apps such as google earth or to view CAD designs?
The message "HmmWhile your browser seems to support WebGL, it is disabled or unavailable" appears when trying to launch these apps.
iko.darius
I have this problem too using Webex board 55, how to enable WebGL?
You will need to have local web access to the endpoint and Select Settings from the menu on the left. Under Configurations, choose the following: WebEngine > Features > WebGLOn.
You can find more info here: https://help.webex.com/en-us/article/pdybr5/Best-practices-for-using-the-Web-Engine
Hope the above helps,
George
gsotirop
