Get Version info of Unity Connection Using Rest Interface
chao guo
Dear Team,
I have a question need your help, I try to using the rest interface of unity connection to get the version of cuc, But I get the response info of version is not the same as the system version.
Unity Connection System Version is "Cisco Unity Connection version: 10.0.0.97026-19", But using the interface, I get the version is "Cisco Unity Connection version 10.0.0.284".
I don't know why this occurs, or the cisco have already update the rest interface of "get version of unity". the following shows the interface info I used.
"GET /vmrest/version HTTP/1.0\r\n";
"Host:localhost:8443\r\n";
"Authorization: Basic " + authorization + "\r\n";
"Accept: application/*\r\n";
"Content-type: application/xml\r\n";
"Content-length: ";
davidn#
Hi Chao,
That's the correct REST API to get the system version. Have you recently upgrade the system or has this worked correctly for you before? Can you send the full request/response so we can examine further? Thanks.
David
Hi David,
The following is the request / response info of get unity connection version.
request:
Host:localhost:8443
Authorization: Basic YWRtaW46Y2NpZSMxMzI0MQ==
Content-length: 0
response:
HTTP/1.1 200 OK
Cache-Control: private
Expires: Thu, 01 Jan 1970 08:00:00 CST
Set-Cookie: JSESSIONIDSSO=1904BE368F7D6DDF71DDC419A34D2F35; Path=/; Secure; HttpOnly
Set-Cookie: JSESSIONID=FA5EB05835C80ED4D984DDF351331ABC; Path=/vmrest/; Secure; HttpOnly
Set-Cookie: REQUEST_TOKEN_KEY=6651972744563398447; Path=/; Secure; HttpOnly
X-Frame-Options: SAMEORIGIN
Content-Type: application/xml
Date: Thu, 27 Feb 2014 01:21:54 GMT
Connection: close
Server:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?><VersionInformation><name>vmrest</name><version>10.0.0.284</version></VersionInformation>
The following picture is the unity connection system info:
   Thanks a lot.
Hi Chao,
Can you post the output of "show version active" and "show cuc version" from admin CLI?
It seems that 10.0.0.97026-19 is the version of common build (CUC+CUCM). The actual version of UC may differ.
The /vmrest/version API makes request on UC database and returns the output of following query which you can verify as well.
run cuc dbquery unitydirdb select FIRST 1 Product FROM tbl_SchemaInformation WHERE IsCurrent=1
Hi Apar,
Yes,  Perhaps you are right, But is there a way to get the version of "10.0.0.97026-19" using AXL API ?
