How to use Cisco AJAX XMPP Library 8.6.1 with Firefox
jjarmul01
I'm trying to use the CAXL to add jabber functionality to a web application. My connection to BOSH servers is working under IE and Chrome but under Firefox I'm getting timeouts when trying to connect and the following error messages:
network timeout retry 1 jabberwerx.ui.js:9677:13
network timeout retry 2 jabberwerx.ui.js:9677:13
network timeout retry 3 jabberwerx.ui.js:9677:13
closed: <stream:error xmlns:stream="http://etherx.jabber.org/streams"><xml-not-well-formed xmlns="urn:ietf:params:xml:ns:xmpp-streams"/></stream:error> jabberwerx.ui.js:9677:13
Failed to connect to SD-Primary Node, binding URL =https://[BOSH Serwer 1]:7335/httpbinding,  and now try the SD-Secondary Node binding URL=https://[BOSH Serwer 2]:7335/httpbinding
The timeouts have less than a second between them.
What do I need to do to make the client work under Firefox?
0 Replies 0
