InstalledLanguage - why no static GetInstalledLanguages?
stephan.steiner
I need to get a list of installed languages from CUPI. No problem - InstalledLanguage myLang = new InstalledLanguage();
But.. if we take UserBase as an example, there's a UserBase.GetUser that takes a connectionserverrest and returns a UserBase as out variables.
So I propose the following change to InstalledLanguages: Add a new static method that extracts the installed languages the same way other objects allow extraction and return a WebCallResult:
        public static WebCallResult GetInstalledLanguages(out List<InstalledLanguage> languages, ConnectionServerRest pConnectionServer)
            WebCallResult res = new WebCallResult();
            res.Success = false;
            languages = null;
            if (pConnectionServer == null)
                res.ErrorText = "Null Connection server object passed to GetInstalledLanguages";
                return res;
            InstalledLanguage lang = null;
            try
                lang = new InstalledLanguage(pConnectionServer);
                languages = lang.InstalledLanguages;
                res.Success = true;
            catch (UnityConnectionRestException ex)
                return ex.WebCallResult;
            catch (Exception ex)
                res.ErrorText = "Failed to fetch languages in GetInstalledLanguages:" + ex.Message;
                return res;
            return res;
That way, you can use the same mechanism to extract installed languages as other things.
Would you consider adding this to InstalledLanguages?
Stephan
Message was edited by: Stephan Steiner, added a sample implementation of what I'm looking for
jocreed
Stephan, I will submit this up as a feature enhancement and will post the bug ID here when I have completed it.
Actually, it's a feature request for Jeff's CUPI.NET lib. I hope he's on a well deserved holiday and I didn't scare him off with my ever outrageous requests.
